I usually get something like that in Firefox, in Threaded Mode, when i zoom in on the text [command +]. It corrects itself when you zoom out [command -]
I imagine the same happens in Flat Kid's-Cartoon Mode!
It's the first time i've seen and experienced this Reply-window-with-big-image thing.
It must mean that the "In response to:" box doesn't automatically limit the width size of the image like in the posts themselves … ???no??
I was saying that since Katpablo had the answer of zooming in and out to fix the problem. How do I do enlarge text on an iPhone? By swiping.. which isn't the same thing and doesn't fix it. Of course he was saying that fixed it for another browser.... but still, I wanted to try.
I know this has been brought up again since this thread was started but I can't seem to find the relevant posts, so this report goes here =D
Well, a thread about ads and stuff obscuring posts would be the best place for a post about ads and stuff obscuring posts. See, you are trainable #6. :-P
six_of_one
Pool Bar
Loc: Alexandria, VA
Update: still happening =)
Here's another screenshot if it helps:
Looks like rather than the ads moving to the left, the messages part appears to be growing to the right to accommodate additional posts and stuff. Which is to say the framework with the ads appears to be a static width while the content frame appears to grow dynamically =)
