Page 1 of 2 1 2
Problem with PM notifications #525841 06/10/10 03:18 PM
padmavyuha Offline OP
Trans Tomboy™
Trans Tomboy™
I just sent a PM to someone here - then the site told me I'd received one (flashing envelope icon), but it turned out to be telling me about the one I'd just sent!
Last edited by Reboot; 06/14/10 05:05 PM. Reason: Moved this to give it its own thread since it's a separate problem.
If it's brokenless, don't suffix it...
Re: Problem with PM notifications [Re: padmavyuha] #525857 06/10/10 05:34 PM
J
John Rougeux Offline
I invented modding!
I invented modding!
J
Just sent you a test PM.
Can you be specific on what you did to send the PM? Send me one.
Re: Problem with PM notifications [Re: John Rougeux] #525939 06/11/10 03:28 AM
Reboot Offline
I sent one to my test sock and it did it to me. I sent one to you and it didn't. But after reading your reply to me your reply still showed as unread in my list, and the icon was still flashing.
This is probably tied to making a reply in a post and then it showing as unread in the forum list.
Also, when I went to read the reply again it still said Unread By: Reboot at the bottom.
The timing is off, something's not updating fast enough. Come to think of it, if it's a timing thing, it may have something to do with this thread, where this thread was moved from.
Two separate problems, but both may be caused by the same.
Or I could be so wrong about it all. grin
Re: Problem with PM notifications [Re: Reboot] #525944 06/11/10 03:58 AM
carp Offline
Dino's are Babe magnets
Yep
I got that too , from a post I made yesterday showed up as unread .
Re: Problem with PM notifications [Re: padmavyuha] #526307 06/14/10 10:02 PM
Reboot Offline
I can't figure any pattern to this. I sent two today, the first one I sent showed as unread after I sent it, the second one didn't.
Re: Problem with PM notifications [Re: Reboot] #526375 06/15/10 01:46 PM
J
I invented modding!
I invented modding!
J
What's weird is that I don't get any of these problems here at work or home.
Re: Problem with PM notifications [Re: John Rougeux] #526391 06/15/10 03:50 PM
Reboot Offline
That is weird. I even cleared all my cookies for here and it still does it.
Re: Problem with PM notifications [Re: John Rougeux] #526606 06/17/10 07:03 PM
Reboot Offline
I'm at a different location, different computer, and I just had the PM notification problem.
Re: Problem with PM notifications [Re: Reboot] #526607 06/17/10 07:07 PM
MacBozo Offline
Ha-ha! Me too. It won't go away!
Re: Problem with PM notifications [Re: Reboot] #526620 06/17/10 09:27 PM
J
I invented modding!
I invented modding!
J
Then I wonder if it's connected to your ID then?
Page 1 of 2 1 2
