#512777 - 03/25/1008:57 AMI fixed error -193 thanks to this post
neil
Neil Ticktin
Loc: Westlake Village, CA
-------------------------------------------------------- This thread migrated from prior board - please excuse the formatting --------------------------------------------------------
posted by Twidge
I found this link that explained the corrupt file. I found it on my machine and was able to delete it successfully and get Now Contact working again.
You can follow their directions at the bottom of the thread or you can do mine which I think is even easier. You will just need your serial number if you do it my way.
Go to the following folder on the main hard drive not your user folder: /Library/Preferences/
Hit either command-F or go to the File Menu and select Find. Select the word "Preferences" and then select "Kind" and choose "Other". This will bring up a whole bunch of parameters for which you can search. Find "File Visibility" and select it. I also click the Menu button so that I don't have to do that process every-time I'm looking for invisible files. Now hit OK
Now that File Visibility is your search parameter, select Invisible Items rather than Visible Items. You should see a file name ".SZIH6.5" Delete that file and start Now Contact. It will give you a the screen to enter your serial number. It should open fine and work just like normal.
