THE BELOW LINK IS A SCREEN PRINT OF THE ERROR MESSAGE SEEN WHEN TRYING OT LOG ON TO THE NUD CALENDAR - HAS ANYONE SEEN THIS BEFORE? IF SO, HOW DO I RELIEVE THIS ERROR?
For an unhandled exception error under Windows, try the following:
First, try opening the sample file. These should be found here: C:\Program Files\Now Software\Now Up-to-Date\Sample Calendar.nud
If that gives you the same error, try refreshing prefs:
1) Quit Now Up-to-Date and Now Contact.
2) Go To: C:\Documents and Settings\{your login name}\Application Data\Now Software
[NOTE: The Application Data folder is hidden. If you can't see it please go into Folder Options in the control panel and set it to show all hidden files.]
3) There you'll find folders named Now Up-to-Date Prefs and Nudcw. Delete those folders.
4) Now, Double Click on your original calendar file and make it primary.
