Hi, I am about to update to Snow Leopard from Mac OS 10.4.9, but want to be sure I will still be able to sync my Centro. If I buy the latest version of Missing/Sync, will the latest version of NUTDC sync with my Centro if I'm running Snow Leopard? Also, any other limitations I should be aware of prior to upgrading to Snow Leopard? Thanks - I'm not ready yet to switch to Now X.
#511716 - 10/26/0911:26 PMRe: Will it sync - Centro & Snow Leopard?
[Re: waterlily]
TheMadCow
Outstanding in the field...
Loc: Los Angeles
I have several clients using the Centro, unfortunately, it uses conduits... and conduits for NUDC are pretty much borked in the Palm architecture. Best bet, and it's not optimal, is to use NowX. Sync to sync services and then use Missing Sync to bring it across.
Geoff Miller MadCow Studios Toluca Lake, CA
