Question In Version 5 there is the ability to edit layouts, and when you select that you can then select envelopes and then edit layout dimensions and edit layout ( most importantly the content and placement of the return address and logo if needed. I cannot find a way to do this in X. In the properties panel it allows for return address of other but cannot figure out how and when the info get entered.
Help!!!!
