I am looking at Address Book and don't see the quantity of fields that exist within Now Contact. When move over to Now X and I snyc between my Palm Centro, Address Book and Now X, and I going to loose data?
Note: you can turn on more columns in the Contact List view in Now X by clicking on the popup at the right side of the list. See http://doc.nowx.com/index.php/guide/6-contacts for more info.
It is not Now X that I am worried about it is Address Book. It looks as if there are very few fields relative the the many fields in Now X. I'm worried that I will loose data when I sync.
Well, you won't lose it. All the information gets sent to Sync Services. If Address Book doesn't have a field for the information, then it ignores it. All of your information will still be in Now X though.
