Anybody having trouble installing Now Software 5.3.2 with 10.5.6? After installing on a MacBook, no icons come up on the right side upon restart. If you wait awhile, they will show up but clicking on a Now icon will make it appear highlighted but not do anything.
Uninstalling does remove Now Software and then the clock and other Apple icons work properly.
Any thoughts would be appreciated.
Todd
Update - I think I just got it to work. Have to link files to the app before the menu apps work!
Sounds like you got it figured out .. but this is for others who might find this...
When I first installed NUTD/C, the menu bar items didn't show up, so I went into prefs for both apps and deselected then reselected display in menu for QuickContact and QuickDay - they showed up instantaneously.
Can you please explain what it means to link the files to the app and how to do it. I am stuck after multiple reinstalls, pref dumps, check/unchecks, etc. with no Quickday in the menubar. It hurts!
