TheMadCow
Outstanding in the field...
Loc: Los Angeles
While I see that it is the windows version, this should work on either platform. Try changing the display resolution up and down and it should allow you to grab the window at some point. The other option is on another machine, use VNC or remote desktop. This can let you display windows that are frequently offscreen on the primary system.
Let me know if any of this works on the PC, I'm curious.
Geoff Miller MadCow Studios Toluca Lake, CA
I have having the same issue with the new appointment window and I tried both suggestions and niether worked. I tried raising and lowering the res and also took control from another system and it is still stuck under the top menu bar even when not maximized. any suggestions would be greatly appreciated
Which Now Up-to-Date & Contact version are you using, and under which operating system?
