iCal to NUTD [Re: skim1420] #506006 07/16/08 08:54 PM
Kempy Offline OP
Can someone tell me a way of easily importing iCal appointments that have been emailed to me. I get them constantly and just want to absorb them straight into NUTD. Thanks.
Simon
http://www.bramshaw.com.au
Melbourne - Australia GMT +1100
iCal to NUTD [Re: skim1420] #506007 10/25/09 06:35 PM
D
DiliMowl73 Offline
D
Ive missed several important appointments because I forgot to turn on an alarm for the appointment in ICal. Id like the default to be that an alarm goes off automatically for each appointment unless I turn it off. How do I set this up?
iCal to NUTD [Re: skim1420] #506008 11/30/09 08:07 AM
D
DiliMowl73 Offline
D
Thanks for the info, im all registered you can move the post.
Re: iCal to NUTD [Re: skim1420] #506009 02/15/10 09:47 PM
M
mwbronson Offline
M
What was the solution to this?
Re: iCal to NUTD [Re: skim1420] #506010 03/02/10 08:01 PM
R
ryoder Offline
R
Drag the file from your email to your Desktop. Then, in Now Up-to-Date, go to File > Import iCalendar file... Then you can choose the file from your desktop and import it right in.
Rachel Yoder
Now Software - Tech Support
_________________
