I'll be on a ten day trip. I xfer my nudc files to the laptop from desktop and all seems OK. When I get back I'll xfer the changed files back to desktop and get rid of duplicates on laptop. Is this a safe procedure? Thanks Bob
That should work effectively. When you copy the file back from the laptop to the desktop, you can replace the desktop data files. If you keep your Now Up-to-Date and Now Contact linked, just be careful about maintaining the file names.
