now contact won't open, now up to date works fine. i have version 5.3.2 and leopard on my mac. i also have now server on my computer but don't use it since leopard was installed a few months ago. thanks diana
Are you getting any error message?
When you installed 5.3.2, if you did the 'Customize' installation and upgraded Now Server Manager when you upgraded Now Up-to-Date & Contact, the event and contact servers should work.
