I can't attach the pages doc... but word doc "goes into" contact just fine. Maybe nudc has some check allowing only certain file types to be linked?? I'm using word 2004 version .doc if you have the newest version maybe that's not recognized as linkable??
From an earlier post by dsawyer:
Hi, Mark,
The problem appears to be that NUDC 5.3.2 cannot attach any file that's actually a package rather than being a single file. Pages and Numbers files are all packages, not monolithic documents, and so cannot be attached.
Regards.
_________________ Dave Sawyer ----------- Mac Pro 2.66Ghz 4GB RAM Mac OS X 10.5.1
His assessment of the situation is correct.
A workaround that may be useful for some situations is to zip or otherwise compress the iWork document (this will work with any document that's a bundle rather than a monolithic file). Then it will attach to a contact without problems. This does not of course allow the document to be opened directly from within the contact, but might be helpful for those who just want to keep a copy of a document attached to a contact and can deal with having to de-compress the document before it can be opened.
