I recently downloaded NUDC 5.3 (while waiting for the release of NH). I was setting up my contact preferences and I was trying to see if I could get NUDC to connect via bluetooth to my iPhone and then use it to dial my contacts phone number.
I haven't been able to get this to work. Is this possible yet?
Thanks!
Go into the Now Contact > Preferences > Dialing > Expert Setup menu and try setting the 'Port' to the Bluetooth connection with the iPhone. Users of other Bluetooth capable phones have had success with this setup.
Thanks for the info. I gave it a shot but it didn't seem to work. I tried both "Bluetooth-PDA-Sync" and "Bluetooth-Modem" but I'm not sure if I need something special for: Initialization, Hang Up String, Dial Prefix or Dial Suffix.
I'll check around the net to see if I can figure this out.
