We need the same scripts and instructions, for the 192 error on reinstall of NUDC software under Leopard. We are operating Leopard 10.5.2. do you think we need to upgrade to the beta, or stick with 5.3.1?
Why is this affecting only one of our three computers? Also, one of the three is still running on the demo. Is there anything I con do before I enter the proper license number to prevent the crashing?
The beta would be the better option under Leopard, as it does clear some Leopard related issues. As to why only one computer has had this issue, it is a corruption in a specific file that is causing the problem. It does not happen universally, or it would be mush simpler to track down and eliminate. We are working on a 5.3.2b4 that eliminates most of the causes of this error. Until then, we have the scripts, which I have sent.
Thank you,
Could I have the scripts sent to me as well. I've got a producer in the field who very urgently needs to get into a calendar file and cannot because of this error.
thanks, Chris W
They are on their way.
