I am having the same problem. My old Quad G5 died, so I restored from Time Machine to a new iMac running 10.6.2. Now my NUDC gives me that error (-193) stating I must reinstall. I have uninstalled, run the fix error script and reinstalled with a persistent error. I have also tried using Now X but it won't import my NUDC files (I only use these files at the holidays to send cards). Any thoughts on getting NUDC 5.3.2 working?
I tried downloading and running this script. You just double click right? OS X asks for my admin user password and then the script seems to run. I still get the Error -193 message. I have tried trashing the app and all associated files in library and reinstalling and running the script before and after to no avail. I am about to quit and go look for another app.
Mount the nudcm532.dmg disk image file. Open the Extras folder. Open the Uninstaller folder. Run the Uninstall NUDC 5.command. You'll need to enter your administrator login password (you will not see the characters when you type your password) and hit Return/Enter. Quit Terminal when the uninstaller shell script is finished.
If you have placed your local data files in one of the application folders for Now Up-to-Date & Contact, rather than the default Documents Folder location, make sure to copy them to a safe location as the uninstaller will remove all application folders
Now, run the "Fix Error 193 v5" AppleScript linked below, then install NUDC 5.3.2.
I am having the same problems, getting error -193. I had to erase and reinstall Snow Leopard because of another problem. Restored from my Time Machine. Now, I get the error - 193 message. Prior to that, Now Contact worked fine under Snow Leopard. I have tried both manually taking out all files and the app as well as running the uninstaller for 5.3.2. Clicked on the link for the script in the prior post and ran that after doing the uninstall. Still no luck.
I did everything as stated and I still HAVE the Error -193. Help!
Send an email to [url=mailto:error193@nowsoftware.com]mailto:error193@nowsoftware.com[/url] and we will help you resolve that.
