I too am having major problems ever since I updated to Snow Leopard ( now 10.6.1 ) on Macbook Pro 13in and I am constantly getting -193 error. I too have uninstalled old version. Reinstalled v5.3.2 but continue with -193 error. Any ideas to get it going?http://forum.nowsoftware.com/content/posting.php?mode=reply&f=31&t=753&sid=80d07684ac7d3638f55f330deab8449b#
All of a sudden, this morning my Now Up-to-Date and Now Contacts are launching with this error message.
Now Up-to-Date & Contact appears to be damaged and should be reinstalled from the original installer. Error -193
I have tried to do so but the error keeps popping up.
Thank you for any help!
- Mike
P.S. I saw in a previous post that there are some scripts that can be sent to fix this issue. Could they also be sent to me? Thank you very much! [url=mailto:mike@forgetcomputers.com]mailto:mike@forgetcomputers.com[/url]
Finally able to get on the boards (they've been down) and see my problem listed above (193). Can I get the scripts (or whatever tool to fix the problem for BOTH the application and server)?
I had to restore my hard drive from a back up to fix a problem with kernel panics. I got the error 193 message, downloaded NUD 5.3 and did clean install and still got the error message. Trashed Now Up To Date folders in Library - still won't load. Help! What this about a script to fix this? How do I get it?
I am also having the same problem, updated my computer to snow leopard and now it comes up with the error message, and after reinstalling several times it still comes up with the same message. Could someone please send the scripts to me at [url=mailto:emma@joys.com]mailto:emma@joys.com[/url]
I tried downloading and running this script. You just double click right? OS X asks for my admin user password and then the script seems to run. I still get the Error -193 message. I have tried trashing the app and all associated files in library and reinstalling and running the script before and after to no avail. I am about to quit and go look for another app.
Mount the nudcm532.dmg disk image file. Open the Extras folder. Open the Uninstaller folder. Run the Uninstall NUDC 5.command. You'll need to enter your administrator login password (you will not see the characters when you type your password) and hit Return/Enter. Quit Terminal when the uninstaller shell script is finished.
If you have placed your local data files in one of the application folders for Now Up-to-Date & Contact, rather than the default Documents Folder location, make sure to copy them to a safe location as the uninstaller will remove all application folders
Now, run the "Fix Error 193 v5" AppleScript linked below, then install NUDC 5.3.2.
After a new install of 10.6 on my MBP I have the same problem like other Users, who wrote above. I did all what you said. Download the app. Run the Uninstall NUDC 5.command. Run the "Fix Error 193 v5" AppleScript, than install NUDC 5.3.2. But after the reboot the error is still there. So I made a clean install (deleted all datas on the HD), but nothing changes. The script opens, i give my Admin password, then the script closes very quick. I think it don't work no more. As I see, I am not the only one. What can I do, that my NUDC works again? Thank you salome
TheMadCow
Outstanding in the field...
Loc: Los Angeles
I'm getting this on my wifes Mac. Upgraded her to an Intel with 10.6.2. Not having any love with the updated script. I have observed that you can log in as root and the app runs fine. Performed an uninstall, script run, reinstall. Doesn't work under users accounts.
Geoff Miller MadCow Studios Toluca Lake, CA
Once more I have tried the hole procedure as root. The error-193 remains. I am really desperate (like a housewife). What can I do else? Hello John and Donn and Sean and Mark and all other Admins! Help us. I am not allone and I need my NUDC. salome
