Could you rush whatever script workaround exists to "burns@crystal.harvard.edu" ? Some of my colleagues use this on OSX Tiger Macs at Harvard Medical School; this has caused quite a bit of trouble.
I was just about to place a phone call, but found this forum.
Thank you so much.
-John
John,
They have been sent.
I have the same problem with the error code mentioned by all the previous posters.
Could I trouble you to also send me the 3 scripts - and since so many other people are experiencing this problem is there some reason these scripts aren't just posted for anyone who needs them to download themselves?
Thanks
rick
They are on their way.
After doing a system upgrade, I'm now getting this message:
Contact appears to be damaged and should be reinstalled from the original installer. Error -193
I've reinstalled (after deleting all files,running the uninstaller, and then restarting) but it's still showing the same error message. May I please have the scripts that solve this problem? Thanks! alfrancis_1999 AT yahoo.com
