No luck on the wife's computer. I ran the permissions changes and still get no QuickDay or QuickContact in menu bar.
Excellent -- not because it's not working, but excellent because maybe we can now isolate what's happening.
I'd like you to run some tests and copy/paste from your terminal into a reply message so I can take a look at the data. On your wife's computer, do the following:
Code:
cd /Library/InputManagers
ls -al *
That will give you a report that looks something like this:
Code:
Menu Extra Enabler:
total 24
drwxr-xr-x 5 root admin 170 Dec 6 10:50 ./
drwxr-xr-x 4 root admin 136 Nov 29 01:01 ../
-rwxr-xr-x 1 root admin 6148 Jan 19 2006 .DS_Store*
-rwxr-xr-x 1 root admin 434 Dec 6 09:47 Info*
drwxr-xr-x 4 root admin 136 Aug 20 2006 Menu Extra Enabler.bundle/
Smart Crash Reports:
total 24
drwxr-xr-x 5 john staff 170 Oct 18 2005 ./
-rw-r--r-- 1 john staff 6148 Oct 18 2005 .DS_Store
-r-xr-xr-x 1 john staff 436 Oct 18 2005 Info*
drwxr-xr-x 3 john staff 102 Oct 18 2005 Smart Crash Reports.bundle/
Please copy that into a reply message so I can look at the info. (Notice how the perms are wrong for the Smart Crash Reports installed on my computer. Hopefully we'll see something similar for the MagicMenu stuff.)
Also, take a look to see if something is installed in the InputManagers for your wife's user account. To do that, do the following:
cd ~/Library/InputManagers
If that gives an error, then she doesn't have any per-user input managers and we can eliminate that as a variable. If she does, then once again type in the
ls -al *
Copy that (if it exists) into a reply message, and we'll see what perms and ownership is going on for her per-user settings.
Hopefully we'll be able to spot what's going on. Fingers crossed.
Thanks!! John
That is the only computer of the bunch that has a Stuffit MagicMenu icon in the menu bar, so I may need to see if Stuffit put in one of these things that causes all the problems. The computer is 2 years old so I don't even remember how the MagicMenu got there.
No MagicMenu in there? Do you know where the MagicMenu code is installed?
I’ve had stability problems with NUDC version 5.3+ since I downloaded it many moons ago, and have gone back to using version 4.5.3 (MacBook Pro 2.16 core duo; OS 10.4.11). It behaved as erratically as Golem's eyeballs when importing data, and stacked all the imported holidays/birthdays together on January 1. A great way to begin a new year, but the source of much consternation over missed birthdays. I was surprised to see folks still downloading it. The home team must be stretched thin, and the calls for patience seem appropriate.
My question here is, since I'm upgrading to Leopard next week, is the NUDC 5.3.2 version more stable on OS 10.5 than it was on OS 10.4, and is it worth the try-out--or best wait for NH?
I pre-purchased NH almost a year ago, and am anxiously awaiting its release. iCal feels too cluttered and the cal in Entourage too clunky, though the latter will have a new interface and capability array in a few weeks with the new Office.
As frustrating as all this is, and as maddening as the delay of NH may be, I’m hoping it will be worth it in the end. I’ve been using the application since it first came out all those incarnations ago, all those buyouts ago. The interface with version 4.5.3 is still bright, cheerful, and clean. That’s the foundation for my loyalty. It is better to work with than the competition, though iCal on the iPhone is beginning to erode my loyalties.
As one of those who still had server problems with 5.3.2b2, I can confirm that, at least for me, they're fixed in b3. And the menu extras work fine for me, too.
I'm also eagerly awaiting Nighthawk... but UTD/contact seems to be operational on Leopard for me in the meantime.
NUDC 5.3.2 mainly addresses Leopard issues. Note that if you go into the terminal and correct the permissions issues with the InputManager's folder (there are a number of posts here about that), then the QC/QD menus in version 4 will probably work with Leopard as well. The one problem that would remain with the client is for reminders. The "quickdayd" process in v4 will most likely fail in Leopard due to changes in how the MacOS daemon() command works. That was fixed as part of v5.3.2.
Onward!
and Upward! Smile
--John
The QC menu primarily, but not uniformly, takes 10-15 seconds between typing info to results. Spinning wheel plus beach ball too. Its been 3 weeks since the last post on this topic. Is this an open item or is there a fix that rectifies this problem? Thanks
Mark Gilicinski
Loc: in Columbus, OH.
Paul,
This is presently an open issue.
- Mark
