• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Now Software Support » Now Up-to-Date & Contact
      » Community Help » Does any Verizon smartphone sync with NUTD?
Page 1 of 2 1 2 >
Topic Options
Hop to:
#502818 - 09/20/07 12:41 PM Does any Verizon smartphone sync with NUTD? [Re: Carnac]
syuroff Offline
I've been trying in vain to get a Verizon Blackberry 8830 to sync with NUTD. RIM provides PocketMac, which allegedly talks to NUTD (it will ask which categories to sync from your default calendar, so some communications is happening), but it never moves data to the blackberry. Their "support" people are completely unresponsive.
If I put an entry on the BB and try to sync, it complains about error 300001, and doesn't add to the calendar.
Has anyone solved this problem already? Do you have a working Verizon (yes, the boss is a dedicated Verizonophile) blackberry/NUTD combination? If so, please tell me about it. I'm looking pretty bad here, when I can't provide the boss the calendar/bb integration the rest of the world had for 5 years.
Top
#502819 - 09/22/07 11:39 AM Re: Does any Verizon smartphone sync with NUTD? [Re: Carnac]
docsloat Offline
You do not say if you are working from a Mac or Windows. I use a Treo700p with my Mac. Markspace has a synch program for Blackberry, but I am not sure if it works on Windows.
The following has been copied from their latest newsletter:
The Missing Sync for BlackBerry Version 1.0.2 BETA Available
Mark/Space recently made a 1.0.2 beta version of The Missing Sync for BlackBerry available for public download. This beta fixes an application crash that occurs when the Safari 3 beta is installed and improves USB connectivity with the latest Macs and latest BlackBerry devices. If you've experienced problems connecting we suggest you try the 1.0.2 beta.
We plan to continue thoroughly testing beta builds for a bit longer and through the upcoming release of Mac OS X 10.5 (Leopard) before posting the final 1.0.2 version. If you'd like to try out the 1.0.2 beta, then back up your data and download the beta installer from the Testing page on the Mark/Space website (http://www.markspace.com/testing), where you will also find complete release notes listing all included fixes.
<http://www.markspace.com/testing>
Top
#502820 - 09/22/07 01:10 PM Re: Does any Verizon smartphone sync with NUTD? [Re: Carnac]
syuroff Offline
I'm working on a MacBook Pro here- that's why I mentioned PocketMac.
I downloaded the Missing Sync test, but nowhere do I see an option to say that NUTD is my calendar of choice. It seems tied to iCal.... is there something I'm missing?
Top
#502821 - 09/26/07 11:24 AM Re: Does any Verizon smartphone sync with NUTD? [Re: Carnac]
docsloat Offline
When you open the Missing Synch window, you should see all of the conduits that are installed. The window will include iCal, Now Contact, NUDT, etc. This is where you designate the applications and data you want to synch.
When you use Missing Synch, you need to install applications in proper order:
1. Palm application
2. NUDC
3. Missing Synch
This should work for you.
Top
#502822 - 09/26/07 12:44 PM Re: Does any Verizon smartphone sync with NUTD? [Re: Carnac]
syuroff Offline
Yes, I get this, but there is just one "Calendar" under the "Plugin Name" category. This has the iCal icon, and syncs to iCal.
1. Palm application
2. NUDC
3. Missing Synch
A Palm application is required to get a BlackBerry and Now Up to Date to communicate? That seems odd.... if we were discussing a Treo here, I'd understand.
Nevertheless, I have all those apps, and still don't see a way to tell Missing Sync that NUTD is the calendar to be working with.
Top
#502823 - 09/26/07 02:27 PM Re: Does any Verizon smartphone sync with NUTD? [Re: Carnac]
dnorcross Offline
For Now Up-to-Date & Contact > BlackBerry the only application that currently seems to do the job is PocketMac for BlackBerry. Make sure you have the most recent version(4.0.20b, I believe) and perhaps try refreshing the Now Up-to-Date program prefs as an error there can impact any type of sync'ing.
1. Make sure you know where your primary calendar file is stored on your hard drive. You'll need to know where it is to set it as your primary file again at the end of this process.
2. Quit Now Up-to-Date (if it is running).
3. Open a new Finder window and select Home from the Go menu.
4. Once in your Home folder, go to: /Library/Preferences/
5. Find the files named com.nowsoftware.nowuptodate.plist and com.poweronsoftware.nowuptodate.plist and move them to the desktop.
6. Find the folder named Now Up-to-Date Prefs and move it to the desktop as well.
7. Launch Now Up-to-Date, open the File menu, select Open, make sure there is a checkmark next to the option "Make this my primary file," locate your Now Up-to-Date calendar file, highlight it and click Open.
8. Open the File menu, select Save As...Save the file as the same name and location as the original. Click Yes to replace the original. This step should be taken periodically to optimize the file.
9. Trash the items moved to the desktop in steps 5 and 6.
Don Norcross
Technical Support - Now Software Inc
Top
#502824 - 09/26/07 02:53 PM Re: Does any Verizon smartphone sync with NUTD? [Re: Carnac]
docsloat Offline
Sorry about that. I forgot when I was writing that you had Blackberry. I was thinking of my Treo. Looks as though the other post has the information you need. Hope you get it working!! I am sure it is possible to do!!!
Top
#502825 - 09/26/07 03:01 PM Re: Does any Verizon smartphone sync with NUTD? [Re: Carnac]
syuroff Offline
On paper, it's doable. In reality, it's not working.
Of all the troubleshooting steps I've done, I'm not sure if I have removed the 2 .plists advised above. I'll give that a shot when the BB owner returns and report back.
Top
#502826 - 09/26/07 07:08 PM Re: Does any Verizon smartphone sync with NUTD? [Re: Carnac]
syuroff Offline
Well, removing that .plist isn't the answer. After deleting it, and using Save As, I get a pretty reasonable looking log in PocketMac:
[01:54:55.865] Progress:ISyncClientConnectingPhase 1079574528
[01:54:57.897] BlackBerry device pin <#########>
[01:55:04.320] Begin synchronization
[01:55:04.433] Contact sync disabled in preferences
[01:55:04.448] Synchronizing calendar
[01:55:06.424] Made the connection
[01:55:06.624] PocketMac version 4.0
[01:55:10.135] Synchronizing Now Calendar
[01:55:10.159] Reading data...
[01:55:42.159] Synchronizing Now Calendar
[01:55:42.183] Comparing data...
[01:55:42.534] Synchronizing data...
[01:56:11.827] All finished.
[01:56:17.518] 2886 changes/new records.
[01:58:09.865] Tasks sync disabled in preferences
[01:58:09.866] Bookmark sync disabled in preferences
[01:58:09.867] Notes sync disabled in preferences
[01:58:09.867] Email sync disabled in preferences
[01:58:10.723] Finished:0
But there certainly aren't 2,886 items put onto the blackberry. In NUTD he has 5 different entries for today. On the BB, he gets one. Tomorrow: 0 of 2, 1 of 5 the next day, ect.
This is a system that gives every outbound appearance of working, but just doesn't.
Top
#502827 - 09/28/07 12:45 PM Re: Does any Verizon smartphone sync with NUTD? [Re: Carnac]
MagickMike Offline
Loc: Georgetown, DE USA
I don't know about Blackberry (I use a Treo) or PocketMac (I user Palm) but I am wondering if there is some consistency around the catagories selected to sync or to display. I know that on the Palm/Treo side you can tell the sync process which catagories you want and which catagories should display. Could this be the issue? Could everything be going to the BB but it is not set to display everything?
Just a thought.
Michael G. Smith, CCP
Golden Ratio Web Designs, LLC
http://www.goldenratioweb.com/
Top
Page 1 of 2 1 2 >
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek, John Wallace
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.047 seconds in which 0.031 seconds were spent on a total of 14 queries. Zlib compression enabled.
