Hello, I am trying to print my calendar starting on Wednesday and ending on the following tuesday.. When I put Aug. 29th as the start date to print.. it just prints the week, starting on sunday, with the date Aug 29th in it. I have the print settings set to print the current screen in multi-day view (on my screen it shows wednesday the 29th as being the first day and Tues Sept 4th being the last). I am on OSX 10.4.10 and am using version 5.3.1 of NUDC. Any help would be greatly appreciated!! Thanks!
While you can not print that selection using the available options in Now Up-to-Date, it can be done. With your calendar displaying the view you want, use the key combination 'Cmd + Shift + 4' and then hit the space bar to select the active window. After that, a mouse click will capture a screen shot of the calendar, which can be opened, and printed, from Preview.
