For the past month my iMac's (2007, 10.6.2l) CD/DVD drive has complained a lot. Slide in a disc and after a few clicks it slides back out. Try another disk, reads with no trouble. Next - won't read it. Varies from commercial music media to blank disks that I want to use to backup files.
Today when attempting to burn onto a DVD an error message appeared - first one ever - that advised the "disc can't be burned because the device failed to calibrate the laser power for the media".
It's $300+ and several days to repair so I'm wondering if there's a utility or test I can run to reset-recalibrate the unit, or am I just stuck with getting a new one?
Optical drives are all basically POS. Unless it's the extremely rare instance that the laser has a bit of dirt on it yours is probably bad. You could get an external drive for a lot cheaper than having the internal replaced.
I always recommend anyone with a laptop or iMac that plans on frequently using the optical drive to get Apple Care, or an external drive, because the internal will break long before anything else does.
Wow, so it shows up on the desktop? If so your drive is probably just misaligned. Possibly a business card on one side of the slot or the other to guide it out would do it.
Unless it's a disc with a label that has come loose, in which case it would probably wobble a lot when it spun up.
Well I mouse left handed so it's the right button for me, but normally the left button for a righty. I do most everything else right handed. I changed over to left handed mousing about 12 years ago to save on the right wrist.
carp
Dino's are Babe magnets
Loc: Hawaii
Yes it shows on the desktop , never had problems before and I never moved the iMac since the day I got it .
Remember when you mentioned its always better to eject the disc . And I always leave mine in Thats when I found out it would not eject anymore . Maybe thats it ?
Anyway I'll try that biz card trick first , since when I eject it makes that clicking sound and the only way to stop that is to reboot , then try that hold the mouse button . Will try that this weekend when I have time to mess with it .
