#499790 - 03/17/1009:56 AMTrying to figure out what these files are ...
six_of_one
Pool Bar
Loc: Alexandria, VA
Hey hey!
So for work I run two MacBook Pros -- sometimes in Windows under BootCamp and sometimes in OSX. When I transfer stuff from the Windows environment using a jump drive, I keep getting these files showing up when I read the drive in OSX:
At first I thought it might be a virus, so I downloaded and ran AVG on the Windows side, and that found nothing. So I downloaded Kaspersky for the Mac and scanned the jump drive, and again, nothing. I did erase the jump drive a couple times with Disk Utility on the Mac, but the files show up again when I've used the stick in Windows -- so it's acting very virus-y in that it seems to replicate, but neither anti-virus package flagged the files ...
So does anybody have any idea what these files are for and if they're something I should worry about?
I don't see any removal tool yet unless you know the geekery of Windows.
I'm sure there will be a fix shortly. How long has that been happening? If not long ago it has to something done recently. Damn Windows only pr0n viewers.
Another Windows formatted flash drive or HD from a different machine maybe?
#499850 - 03/17/1006:02 PMRe: Trying to figure out what these files are ...
[Re: Reboot]
six_of_one
Pool Bar
Loc: Alexandria, VA
Well, these are show machines, so exceedingly rarely are they connected to an internet connection lest something decide to update during a presentation. Most likely the bug came from a client's flash drive or something.
I tend to be a bit snobbish with my pr0n and only indulge using OSX ;-)
