KateSorensen 77 and counting
Originally Posted By: MacBozo
I still cannot login as MacBozo at either Mactech or MacNews.
I am curious if hundreds of new folk have been able to sign in on the new "enter to win" pages? Is the problem still just for old timer/transferees from outter space [MacMinute]?
As far as I am concerned, the problem is not yours or mine Bozo. I'll wait until they fix it -- or not.
You posted about it so I figured you wanted to try and fix it. Since it's only happening to you I'd say it's probably something in your Firefox setup, and not worth looking into on the server end.
There are still some big changes coming, and you are simply witnessing some of the build-up to it. It's somewhat difficult to do it all at once, so this interim stuff is necessary.
Sit back, relax, and enjoy the ride.
Originally Posted By: Reboot
Since it's only happening to you I'd say it's probably something in your Firefox setup, and not worth looking into on the server end. Thanks anyway.
or I'm the only one who's reported it? All kidding asside, no one would have to look up the problem on the server side afaiac. I can live with my FF setup as it is.
Anyway, I disabled all add-ons etc. Results below. Firefox.
I'm not mad, angry, upset, disappointed, etc. The fact that it does notwork for me doesn't matter.
It works in Safari, but I just like Firefox better for daily use. If I needed the MacTech page perfect, I could switch to Safari.
Giz:
