neil
Neil Ticktin
Loc: Westlake Village, CA
Originally Posted By: yoyo52
Still no registering possible.
Can you do me a favor and "empty cache" and try again? This should be working now (to register on the main MacTech.com or MacNews.com sites). Once you are logged in there, you should be logged in here on the forums automagically.
Yes to the yes-no questions. I don't get a message other than user not recognized. I tried to set up a new account as well, and that didn't work either.
Still no luck with FF. The username field turns red after I try to log in, by the way, and the same happens if I try to create a new account. I've been using my usual username and password. Maybe I should try a different one combination? Or will that jut screw things up completely?
