• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Mac » Software » Remove apps
Page 2 of 5 < 1 2 3 4 5 >
Topic Options
Hop to:
#490676 - 01/24/10 02:03 AM Re: Remove apps [Re: papabill]
NucleusG4 Offline
Master•Blaster
Loc: Miami, Fl.
This is prolly why someone got rid of the box. It's OS is buggered.
Do a clean install and quit trying to figure out a quite likely buggered system on an OS that you don't know.
You'll drive yourself nuts. Plus this will give you a better idea of how Apple intended you to start. Also, quite likely, a faster boot and faster running sys.
http://davidbearphotography.com/
Top
#490679 - 01/24/10 02:07 AM Re: Remove apps [Re: NucleusG4]
NucleusG4 Offline
Master•Blaster
Loc: Miami, Fl.
I found an old thread with some links to browsers for OS9. I clicked on the one for IE and it started d'loading the file.. so I know that one is good.
OS 9 Browsers...
Top
#490682 - 01/24/10 02:48 AM Re: Remove apps [Re: papabill]
MacBozo Offline
YIM (Yahoo Instant Messenger) 3.0 is for OS X. It will not install on your system. You will have to find things that are, at least, 10 years old.
Edited by MacBozo (01/24/10 02:50 AM)
Top
#490686 - 01/24/10 03:48 AM Re: Remove apps [Re: MacBozo]
yoyo52 Offline
The same goes for browsers. Nuc's link gives you some good information and links to compatible apps, but face it--yu're not going to be able to download and install most stuff.
MACTECH ubi dolor ibi digitus
Top
#490688 - 01/24/10 04:45 AM Re: Remove apps [Re: yoyo52]
NucleusG4 Offline
Master•Blaster
Loc: Miami, Fl.
That's why I pointed out the IE link... it downloads IE 5.1.7
Top
#490689 - 01/24/10 04:48 AM Re: Remove apps [Re: papabill]
Reboot Offline
Loc: Columbus OH
Originally Posted By: papabill
Plus, why is there a 45-60 second delay between the time I hit the 'on' switch and the monitor shows the machine is actually booting up??
Wierd!!
Probably because you had to shut the machine down hard, the hard drive is doing some clean up. You should do as suggested and invest about $100 in a newer G4 Mac that is running OS X. You have a hard battle ahead otherwise in OS 9, and the results won't be satisfactory.
AppleCentral Trivia
MM-MCF Trivia
Call the Doctor
Top
#490702 - 01/24/10 01:17 PM Re: Remove apps [Re: Reboot]
papabill Offline
Where's the cache?
Loc: Belmont, NC
Well, all this spawns another vital question:
I got the machine for free. It has OS 9.2 installed on it. I am disabled, living on Social (in)Security, and have a VERY limited income. I was able to secure an Apple Macontish CD for the Power Macintosh G3 . It has OS 8 on it (must be the install disk).
My question would be if it'd be better to reload OS 8, since the current OS seems "damaged" or try to fix the current OS?
OR -- would it be better to load OS X on this thing - 1- would OS X work on this G3, and if so, 2 - where would I locate an OS X install CD
Thanks
Top
#490704 - 01/24/10 02:13 PM Re: Remove apps [Re: papabill]
Reboot Offline
Loc: Columbus OH
Unfortunately OS 8 will be worse than OS 9.2 on the internet, probably almost impossible. You'd go from something that is somewhat usable, to something that is pretty much just a novelty and not very functional for everyday use.
You can put OS X 10.2.8 on that machine all depending on how much RAM is in it and how big the hard drive is. ebay usually has Jaguar (10.2) install CD's for $25 shipped. It would give a better example of what the Mac really is right now, but even with it some internet stuff isn't going to function right.
Did you try moving anything with Norton in the name from your Control Panels folder and from your Extensions folder like yoyo suggested?
You can also set Extensions Manager that is in Control Panels to Mac only extensions and it will move all the Norton stuff to the appropriate (Disabled) folders in the System Folder, and also move any other third party stuff that might be causing problem too.
AppleCentral Trivia
MM-MCF Trivia
Call the Doctor
Top
#490706 - 01/24/10 02:36 PM Re: Remove apps [Re: Reboot]
papabill Offline
Where's the cache?
Loc: Belmont, NC
Yeah, I got rid of Norton. Just deleted all the folders, and I don't see any Norton activity now.
The machine is 266Mhz, with a 6Gb HD, and 640Mb of memory.
Top
#490726 - 01/24/10 05:58 PM Re: Remove apps [Re: papabill]
Reboot Offline
Loc: Columbus OH
Did you delete the files from Extensions and Control Panels along with the folders?
AppleCentral Trivia
MM-MCF Trivia
Call the Doctor
Top
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
View homepage
Add to your Watched Users
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.044 seconds in which 0.032 seconds were spent on a total of 14 queries. Zlib compression enabled.
