#488975 - 01/14/1009:29 AMRe: You can not beat this logic...
[Re: keymaker]
steveg
Making a new reply.
Loc: D'OHio
The case may vert well succeed because the load-bearing pillar is the assertion that same-sex marriage harms no one, while denying the right to marry harms affected couples, the children that they may be raising (oh, I know that point will knot your BVDs in a heartbeat), and their families.
#488999 - 01/14/1012:16 PMRe: You can not beat this logic...
[Re: keymaker]
steveg
Making a new reply.
Loc: D'OHio
Hullo... is this mic on? Proposition 8 overturns the rights of same-sex couples to marry in California. Why do you keep bring age into this? It's got nothing to do with P8.
#489006 - 01/14/1012:35 PMRe: You can not beat this logic...
[Re: steveg]
keymaker
I invented modding!
Cp.. turn it down a bit, jeeez... no, the only reason I mentioned age is that you started talking about denial of the right to marry which is basically about age.
Okay, there are other objections such as, you know, bigamy or incest - the 'prohibited degrees' but other than that no restrictions.
