Silver_Moon Record enthusiast
Loc: Teetering between IL and AZ
This time, When I try to put my 2 Gig SD card in the SD reader on the side, It makes the sound like it detected, it, but It doesn't show up in My Computer. I waited an hour- Nothing. It works fine with my 128 MB card and my dad said it should read any capacity. What's up?
"I'm a little bit more unusual so I've always considered myself the black sheep." - Ann Wilson
#487943 - 01/09/1004:58 AMRe: More Dull problems!
[Re: Reboot]
Yeah, It detects my other card. Heres a video (of My favorite xbox360 game) from my 128MB card, Its not big enough to really do anything with. Like I said, it should be able to read any card. [video:youtube]http://www.youtube.com/watch?v=nsOMexIrAMo[/video]
Check out Device Manager like I suggested, try it without and then with the 2G card in to see if Device Manager recognizes the card, or changes the description of the reader or anything when the card is put in.
If you need to get the pics off the card you can probably plug your camera in and just use it as the reader. Not ideal but it may work.
Do you have XP SP3 installed? SP3 fixed mainly SDHC card problems, but it was to correct a fault of XP to read the drivers. MS has a hotfix if you're on SP2.
