When you jailbreak it with blackra1n, it gives you the option to install Cydia or Rock. Install Cydia, and put "Mac os X Snow Leopard" in the search section. It will install Winterboard, and you have to go into that and enable the theme. You should be all set then.
Yeah, I have Cydia and Winterboard installed. What is that theme called?
