What's up with this!? There's nothing in the Recycle Bin when I open it, but the icon says there is, and when I say to empty it, it asks me that! WHAT is going on!?
I don't wanna see what happens! It might screw up the whole computer! Is there any other way to fix it?
I have no idea, but that's how we learn.
If you set the window options to show invisibles can you see the Windows folder in there? Maybe it got moved accidentally, or maybe it's just a copy. Without having any details as to what went on before it's hard to say.
Usually when this happens the recycle bin directory is corrupted, or there is a piece of spyware in there. Empty the bin (you'll get an error), then reboot the machine in safe mode. Empty the bin then if it's not empty, and reboot into regular mode. Should take care of it.
Regular user can't move the windows folder to the trash anyway.
