My Mac just spontaneously rebooted without any input from me (I was across the room). Recovered files in the Trash point to RealPlayer/Downloader. System log only reports "Shutdown detected." There are a lot of out of sync messages during/after the restart. Also, it states that network configuration changed. There is nothing in the crash logs that would reference the reboot. When will I get the time to run DW and TTPro?
I just had my TV come on suddenly. Couldn't figure out what happened . . . then noticed that I was sitting on the remote. Wonderful what a butt cheek can do!
Can't see anything obvious in the log from a quick look, logging just stops.
Do you have Energy Saver set to Restart after a power failure? I'm thinking a power blink on your incoming, or the power supply on the mini shut itself down. I figure you have a battery backup though being in lightning land. I had a battery backup go bad that would just blink off for a second.
