Since I've updated to 10.6, after I type a new email and send it, a copy of it remains in the Drafts folder and I then have to delete that copy manually. No big deal, just the first couple of times I had to check to confirm that the message had actually been sent, and was in the Sent folder too.
Mail.app. It seems random - though more likely to happen with messages with attachments. And sometimes they eventually go away, but sometimes they're there a day later and I have to delete them manually from the Drafts folder. Very odd. They're happily showing in the Sent folder, but not getting deleted from Drafts. I think I'll check my server settings and see if something got changed during the upgrade.
iBookmaster
WTF (Why The Face?)
Loc: USA
Yep, I am getting that problem.
_________________________ Well, until they make it right, I hope they never sleep at night. They better make some changes and do it soon. -Things Goin' On/Lynyrd Skynyrd
I have no idea if this is what you're experiencing, but it seems to be what's up with my new MBP and its installation of Snow Leopard. I use a mac.com account, and the Mail in Snow Leopard automatically makes those accounts MobileMe accounts. So the emails I send from my computer become drafts on the MobileMe server, which have to be hand-deleted. It doesn't happen with every email I send, though, and I haven't figured out what's up with that.
