Can not allocate memory error #479344 11/26/09 01:03 PM
F
firestorm Offline OP
n00b
n00b
F
For some reason I recently am having an issue pinging or ssh to systems behind a vpn connection. This issue only occurs when I connect on the Mac (OS X 10.5). On Linux and Windows it works fine.
I will get the following after making a VPN connection via the cisco vpn client v4.9
ping: sendto: Cannot allocate memory
I get a similar error when trying to ssh to a server.
I have noticed that after connecting, ifconfig -a does not show the assigned address the vpn appliance ASA will provide the client.
This issue only occurs after connecting to a VPN. I tried restarting the vpn clients sub-system, no go. I installed and ran applejack, still no go.
Is there a way to rebuild the tcp/ip stack in a MAC if this is the only solution available?
Any ideas?
Thanks,
Re: Can not allocate memory error [Re: firestorm] #479921 11/29/09 11:20 PM
SgtBaxter Offline
F'n HO.P.A.
F'n HO.P.A.
MAC is the address of your ethernet device.
Mac OS is the operating system. :P
And yes, simply go into system preferences and toss the preference file.
I think its here -> HD>Library>Preferences>System Configuration>preferences.plist
Although I doubt that's your problem, I think the Cisco client is the issue. Don't know if it will work, but best bet is to reinstall the client.
Hey I'm an F'n Jerk!
twitter.com/SgtBaxter
facebook.com/Bryan.Eckert
