2nd Gen Shuffle (& eventually 3rd Gen NANO Help Needed)
It was working fine ..had a good charge.. I went out to clean the gutters with a bit a music and when I came in the Green Indicator Light was Orange so I set it in the cradle and went about my business.. A few hours later the Indicator lite was RED! ...and it's thwarted every attempt to charge back to up.
I reckon it's the Battery .. so I started searching for a new one.. (no easy!) then the disassembly instructions (also not an easy find) then found out WHY........
There are NO Battery Connectors on the tiny Shuffles.. OR The NANOS! (Figures! we have one of each)
What's needed is a bit of MICRO-SOLDERING (battery leads to LogicBoard) ..mmm.. NOT the place to LEARN to Solder.
Any practical (workable) solution?
Oh.. I found a place to order a battery for $15.. and a different outfit you can sent an iPod to and they'll gladly install any of your 3rd party parts for you .. at a flat rate fee of $35.00 +S&H & Insurance.
Falls into the "May as well buy a New One" since the price drop that's now HALF what I paid when it was first issued.
What grinds me is the meticulous care I've taken with the little darling.. always in a silicon iSkin and always in a leather case when not in use.. to look at it it looks like it's a freshly UNBOXED Virgin. that alone makes me loath to chuck-it in the bin.
I had that problem with mine, and all I had to do was restore it to factory settings.
Good Idea!
too bad it didn't work
but thanx for the suggestion.
I restored to factory settings then added back a playlist, and left it charging all night. This morning I disconnected it and flicked it on and the indicator light flashed RED then went out.
O It still plays as loud & lovely as ever ..but I assume not for much longer.
PChaterosx
Belongs in the 1980s
Loc: Time traveling in 1980
Originally Posted By: Celandine
Good Idea!
Then I think that your battery is going bad... I don't think that it'll be worth trying to fix... because if it was fixable... It would've worked. I'm getting an iTouch soon so anyone that wants my shuffle is welcome to it.
The hugest gripe I have with Apple products.
Lithium batteries oxidize and die, plain and simple. Sometimes they die quicker, somtimes slower, but 2-3 years after you purchase the device the battery will need replacement unless you can live with severely reduced runtimes.
At least the larger devices you can pry open and remove the battery, even if it's not easy. But soldering the battery in is just planned death for the device, and not really environmentally responsible.
