#477879 - 11/16/0908:18 PMRe: I might go back to Leopard (10.5)
[Re: trey]
I never used FiderPop in 8 or 9, but I just downloaded it and read the guide, and wonder how necessary it is in the OS X environment. I see it would've been very neat in pre-X systems. Have you started using it again, trey? Is it all it used to be?
#477882 - 11/16/0908:26 PMRe: I might go back to Leopard (10.5)
[Re: yoyo52]
trey
Loc: The Wizard's Balcony
Well, I just installed it like twenty minutes ago, so I'll take it for a spin and let you know. I rely heavily on QuickSilver, and only go to the mouse if I really have to, so it might be a bit cumbersome. But I'm willing to give it a shot, and I definitely owe Turley a pint either way.
