If I get an unlocked iPhone can I use it under Verizon? I'm in France for the next year or so, so I can get an unlocked one here no problem, but when I go back to the states I'd like to use it there.
i have tried this, it's easer to use a first generation iphone because the later generation uses a frequency on at&t towers that's different from Verizon towers
iphones work best if there using the same type of signal they would have used on the at&t network
