I'm looking at a hp laptop with amd turion 64 x2 dual core and immediately thought hack, hack, hack! i know about bit torrent and the leopard downloads but i was concerned with the differences of amd and intel, any comments or should i just go with it?
google osx86 and check the compatibility charts on their wiki. Lots of info on what works and what doesn't, but keep in mind that it isn't completely up to date.
Depends on the nForce chipset. The what I call "aftermarket kernels" support nForce chipsets but you'll still run into problems like ethernet, wireless and sound. People that do use AMD products use desktops and drop in compatible parts to bypass the stuff that isn't compatible. For all you know you might end up having just the basic hardware like VESA video, storage, optical and keyboard.
