Page 1 of 2 1 2
iPod dock connecter [Re: Kirkulus] #475991 09/23/08 03:28 AM
9
987687 Offline OP
Where's the cache?
Where's the cache?
9
Where can I get an iPod dock connector that has power in, and audio out? I would like to have a direct input to my car, and just use one cable.
I know that I can get an FM transmitter or something with such a cable, but that is to expensive to pay for the plug. I do have a cable that powers the iPod, but I have a separate plug for the audio, and on the old iPods the audio and dock connector are on opposite sides. Is there some site that sells just that plug?
Re: iPod dock connecter [Re: Kirkulus] #475992 09/23/08 04:56 AM
O
oojacoboo Offline
O
Why not just have that be two wires with the old dock and just tape em together or something?
Re: iPod dock connecter [Re: Kirkulus] #475993 09/23/08 11:10 AM
9
987687 Offline OP
Where's the cache?
Where's the cache?
9
Because the headphone plug is on one end of the iPod, and the dock connector is on the other. If I had a newer one where it had the connectors on the same side I would not care.
Re: iPod dock connecter [Re: Kirkulus] #475994 09/23/08 01:03 PM
RadioC1ash Offline
You could use one of these, though you wouldn't need the composite video.
Re: iPod dock connecter [Re: Kirkulus] #475995 09/23/08 01:59 PM
9
987687 Offline OP
Where's the cache?
Where's the cache?
9
It would be cheaper to buy a FM transmitter that used the cable I wanted. The other problem with my iPod is that the headphone plug is getting old, so if I jiggle the plug it will pause. And it will often pause when I break hard, or take a sharp corner. So if I have the power and sound going through the dock connector I will kill 2 birds with one stone.
Re: iPod dock connecter [Re: Kirkulus] #475996 09/23/08 04:08 PM
O
oojacoboo Offline
O
The ipod dock that I have integrates a line out and the proprietary ipod plug next to each other... Would this not be sufficient?
http://www.ixbt.com/td/images/ipod-nano-2-dock-back.jpg
Re: iPod dock connecter [Re: Kirkulus] #475997 09/23/08 06:03 PM
9
987687 Offline OP
Where's the cache?
Where's the cache?
9
I would have to find some way to mount it, but yeah, that would do the job.
Re: iPod dock connecter [Re: Kirkulus] #475998 09/23/08 06:14 PM
9
987687 Offline OP
Where's the cache?
Where's the cache?
9
I think I am just going to buy one of these
http://home.swipnet.se/ridax/connector.htm?connmale.htm
Re: iPod dock connecter [Re: Kirkulus] #475999 10/01/08 07:25 PM
RadioC1ash Offline
I'd like to see what the inside looks like as far as the back side of the pins. Are they set up with solder wells? Or maybe a small PCB?
Re: iPod dock connecter [Re: Kirkulus] #476000 10/01/08 09:03 PM
9
987687 Offline OP
Where's the cache?
Where's the cache?
9
Well, my iPod stopped working today frown
And then later today I checked my mail and the connectors had come. Oh well, this one is on hold for a while. But I will post pics of the connector.
Page 1 of 2 1 2
