Last year I painted a G4 sawtooth case red and black. I decided to take it further and get rid of the shinny chrome inside the case. I found a can of Metalcast red paint in my paint supplies box and took off a panel on the case to do a test so if it didn't come out right the panel would hide the mistake. The paint test came out great. I removed all of the panels and gutted the system and painted the whole metal frame of the case in the red metalcast. Since I didn't want just red I painted a the CD-ROM/Zip Drive cage in a semi flat black. I also gutted the power supply and painted the power supply cage/case in semi gloss black as well.
Next step is to mount the 120mm fan back but with out that rail. I'm thinking to use some riser studs for that.
I also need to get some black round IDE cables and a wire sleeve kit for the power supply cables.
The only thing I don't like about this is the PCB materiel Apple chose doesn't fit the scheme at all. Having green colored circuit boards in a red case looks ugly as heck. I could put white glue on most of the contacts then paint it with a enamel and peel the glue back off but that would be too much work.
Here's a link to liquid electrical tape. You might try this stuff. I've used it to repair all kinds of oddball stuff. I know it comes in black, red and white. Maybe a few others by now. The can comes with a brush inside and one can would easily cover one side of your MoBo. I'd get two for one side though, depending on how black you want it to be. http://www.dxengineering.com/products.asp?ID=191
"Far better it is to dare mighty things than to take rank with those poor timid spirits who know neither victory nor defeat." - Theodore Roosevelt
-USMC Corporal Hess Sherrod B:6/6/84 D:4/6/09 I miss you, my brother.
I'll live with the green and toss on some red bling. Maybe a few LEDs and such.
I'm tired of wire looming. I've been using it for years on my PC mods and my car is also loaded with it. I might try some automotive silicon rubber tubing to cover the cables so it looks like one massive cable instead of 4 running to each device. Not to mention it will insulate better. Hard part is to cover up the connection to the logicboard.
