Clear case mod for c2d imac? [Re: H. Habilis] #475696 07/24/08 11:52 PM
F
Fazer Offline OP
F
Hey guys,
I've got a c2d imac, and was wanting to put alittle flare to it. I was wondering, has anyone thought of a clear casing to replace the white casing, or does someone already make such a thing?
2.16 20" c2d imac / 250gb / 1.25gb
600mhz g3 ibook (3DOA)
Re: Clear case mod for c2d imac? [Re: H. Habilis] #475697 07/26/08 10:05 PM
F
Fazer Offline OP
F
no one? :-
Re: Clear case mod for c2d imac? [Re: H. Habilis] #475698 07/27/08 01:02 PM
M
mattruben Offline
M
No one makes such a thing. The toughest aspect would be the cost of paying a fabricator, as it would take a lot of technical skill to make it yourself.
There are also two other problems:
(1) Unlike the original G5 version of these iMacs, the Intel-based ones have the side and rear part of the case as one piece - so you'd need to make the front bezel and the side/rear (whereas with a G5 iMac you could just make the front/rear piece clear, which would be easier).
(2) But the biggest drawback by far is that the Intel iMacs (again, unlike the G5 iMacs) are butt-ugly inside - the internal components aren't arranged very nicely, and there are sheets of metal EMI shielding all over the place.
M
Re: Clear case mod for c2d imac? [Re: H. Habilis] #475699 07/28/08 08:01 PM
F
Fazer Offline OP
F
Ah, did not know that. Thanks for the info, ill know now to keep the pretty snow white case.
Re: Clear case mod for c2d imac? [Re: H. Habilis] #475700 07/29/08 04:45 PM
F
flippy10 Offline
F
I wonder, think you would be able to RIT dye the case of the iMac? A red one would be quite sweet.
Re: Clear case mod for c2d imac? [Re: H. Habilis] #475701 07/29/08 09:02 PM
W
Waragainstsleep Offline
W
Now you're talking. Not the simplest task, but potentially fabulous results.
Re: Clear case mod for c2d imac? [Re: H. Habilis] #475702 07/30/08 12:41 AM
F
Fazer Offline OP
F
hmm, nice point flippy. I am looking into it as we speak. If anything sparks, ill make sure to keep you guys updated.
