I have a dream, and two Sawtooth´s and one MDD. The MDD has no PSU and since I have no real use for it anyway, I have decided to try and install its CPU on a Sawtooth motherboard, in that process I have had to sacrifice the AGP port as well as one PCI port, but to no avail. Although it fits perfectly in the socket it wont start up, what do I do, what have I done wrong, can it ever work? The MB works perfectly, I have no way of knowing if the CPU, but I have no reason to beleive that it does´nt.
I have of course documented the entire process, but I must admit that it was difficult to both remove the PCI slot and operating a camera at the same time.
