• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Mods and Hacks » General Mods » Miscellaneous » APC UPS Battery Backup Mod
Page 1 of 2 1 2 >
Topic Options
Hop to:
#474793 - 02/29/08 02:30 AM APC UPS Battery Backup Mod [Re: befriton]
oojacoboo Offline
OK, so, I have an APC UPS Pro 1000 (aka 1kva). So, the battery has just died on it, and I am thinking I will just connect up a deep cycle marine battery. However, I am wondering a few things.
Does the onboard computer have a memory of how much voltage is in the battery, or does it actually take direct readings? So, in other words, if I hook up a battery to the UPS, will I get the full battery power, or will I be limited to the same capacity of the current battery?
Also, any recs on the casing? The one I have now won't fit a large deep cycle marine battery...
I was also considering hooking up 2 or more batteries in a parallel circuitry. Does anyone foresee any concerns with this?
Any and all tips and recs appreciated.
Mac Pro Quad 2.66 - 4GB RAM
Quad 19" Widescreen LCDs
Accessorized to the Hilt
Top
#474794 - 02/29/08 04:10 PM Re: APC UPS Battery Backup Mod [Re: befriton]
whitlock Offline
Moderator Emeritus
I think those suckers take readings of the voltage, though if it's higher or lower than the stock battery it may freak out and not properly condition power / recharge if there is a failure. Not really a memory issue, but how the hardware is on the board.
It's worth a shot if you have a spare laying around. Worst thing that can happen is that it fails... well that or explode. I suppose exploding would be the worst.
If it doesn't work, call a battery store and check how much a new cell at that range would cost.
Top
#474795 - 02/29/08 07:09 PM Re: APC UPS Battery Backup Mod [Re: befriton]
BigO Offline
I think the worst would be if it turns into Venom and foils all your crime-fighting plans.
I think I need to get out more.
Top
#474796 - 02/29/08 09:08 PM Re: APC UPS Battery Backup Mod [Re: befriton]
Waragainstsleep Offline
As I understand it, 'smart' batteries cannot measure the charge currently contained within themselves (there is something awful about that sentence, but I think its OK).
The charge is measured as it enters and leaves the battery. When you recalibrate a battery by charging it full, discharging fully, then charging fully again this resets the 'charge-o-meter' to 100%.
Thats how Apple laptop batteries work at any rate. If yours is as smart, it should be able to recalibrate itself to a new battery. I confess I don't know much about the variations of currents and voltages used to recharge batteries and their associated tolerances. I would guess that a nasty miscalculation of this is the sort of thing that could make a battery explode.
3rd party batteries with higher capacities seem to work fine with Apple PMUs, SMCs etc. As far as I know, the electronics are identical to Apple batteries but the actual cells are upgraded.
Top
#474797 - 02/29/08 10:15 PM Re: APC UPS Battery Backup Mod [Re: befriton]
oojacoboo Offline
hmm, so...
Not really sure about this, I def am not looking to have an exploding battery... I don't think thats going to be the case, but at any rate, I wanna be sure that this will work.
Anyone with any experience on this?
Top
#474798 - 03/02/08 02:21 AM Re: APC UPS Battery Backup Mod [Re: befriton]
TCPMeta Offline
MacModder
You can use the battery but use a automotive 20amp fuse on the battery.
To live is to let die
Top
#474799 - 03/02/08 02:41 AM Re: APC UPS Battery Backup Mod [Re: befriton]
oojacoboo Offline
20 amps is the standard current for the electrical in your home?
Top
#474800 - 03/02/08 03:46 PM Re: APC UPS Battery Backup Mod [Re: befriton]
20A is a reasonable and safe amount of power for pretty much any appliance(s) you might need. In the UK, you don't often see fuses over 13A in appliances, I think they go to 30A in domestic fuseboxes.
Top
#474801 - 03/02/08 09:49 PM Re: APC UPS Battery Backup Mod [Re: befriton]
TCPMeta Offline
MacModder
For 12volts most fuses are 7.5, 10, 20 and 30 amps. If you use something that needs a crap load of amps or wattage then 40 or 50 amp fuses are needed. For examples my carputer power supply uses a 10amp fuse and I also modded my gaming PC's power supply to use 10 amps for 12 volts and 7.5 amps for 5 volts for the DC outputs. My car amp uses a 40amp fuse for the main power but the amp has a 15 amp fuse. So if theres a power surge the 15 will blow first and if it effects my main power the 40amp will blow.
Your UPS is nothing more then a power inverter with a battery. It turns 12 volts DC into 120 volts AC. When it's plugged into the wall it's going into two way. Straight power to the device and also into a battery charger keeping the battery charged.
The UPS should have a voltage regulator so you shouldn't really even need a fuse but I would add one just for as a safety. Last thing you need is to test it or wait for a power outage and too many amps end up into the PC or even into the battery.
Top
#474802 - 03/03/08 03:13 AM Re: APC UPS Battery Backup Mod [Re: befriton]
oojacoboo Offline
yea, so, I am wondering, I am probably draining some decent power here...
Mac Pro w/ 3HDs
4 LCD's
Cable Modem/Router
Backup 2-HD RAID Kit
MacBook
Printer
100Watt Lamp
iSub/iSticks
There are some other smaller things, but those will be the major power suckers...
So, you are recommending a 20A on the lead from the UPS to the battery? On the positive terminal, right?
If I run a couple in parallel, would you put one on each positive lead?
Top
Page 1 of 2 1 2 >
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
View homepage
Add to your Watched Users
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.092 seconds in which 0.078 seconds were spent on a total of 14 queries. Zlib compression enabled.
