Bought a iPod for 10 bucks. [Re: monneysi] #474735 02/25/08 01:25 PM
T
TCPMeta Offline OP
MacModder
MacModder
T
A friend of mine at work heard about the fateful death of my iPod. He had a iPod nano (2GB) but no computer. He got it as a Christmas gift. Well he came up to me and said I have a iPod to sell you. I asked how much and he said 10 bucks.
Well since I have a working LCD from my 5.5gen I wonder if I can modify the nano to use the LCD from the 5.5gen. I don't care about the hard drive size. On the old iPod I used about a gig out of 80GB. I just hate how small the screen is.
Anyone willing to help me dig up the pinouts for both LCDs?
To live is to let die
Re: Bought a iPod for 10 bucks. [Re: monneysi] #474736 03/03/08 04:42 PM
F
flippy10 Offline
F
I searched for quite a while yesterday and found nothing... Not to mention that those LCDs have insanely small pins. Way beyond my solder abilities.
Re: Bought a iPod for 10 bucks. [Re: monneysi] #474737 03/03/08 07:58 PM
O
oojacoboo Offline
O
just sell the nano and upgrade to the larger one if you must.
Re: Bought a iPod for 10 bucks. [Re: monneysi] #474738 03/03/08 10:12 PM
F
flippy10 Offline
F
Seconded. You can snag a 30GB Video with a broken LCD for ~60$ on eBay. And a fully working one for probably something of 100 or so. Maybe even less.
Re: Bought a iPod for 10 bucks. [Re: monneysi] #474739 03/04/08 12:44 PM
T
TCPMeta Offline OP
MacModder
MacModder
T
True
Re: Bought a iPod for 10 bucks. [Re: monneysi] #474740 03/05/08 01:50 AM
F
flippy10 Offline
F
A fun thing to do to the Nano is switch out the black clickwheel for the white/gray one. It looks pretty awesome. Or even better then that, you could get a hold of a White Nano, and RIT dye it.
Re: Bought a iPod for 10 bucks. [Re: monneysi] #474741 03/05/08 12:58 PM
T
TCPMeta Offline OP
MacModder
MacModder
T
My nano has a white click wheel.
Re: Bought a iPod for 10 bucks. [Re: monneysi] #474742 03/05/08 04:12 PM
F
flippy10 Offline
F
So then find a black one? It goes both ways.
Re: Bought a iPod for 10 bucks. [Re: monneysi] #474743 07/21/09 05:25 PM
J
johnodd4 Offline
J
They are right you can go to pawn shops and get 30 gig ipod photo's for 40.00 a lot of pawn shop's are unloading older ipods this might be a good time to check them out before ebay.
Remember though if you through ebay and the ipod you purchased doesn't sync with itunes.
Format the ipod in disk utilitys or even windows in fat 32 and do a restore in itunes this will fix any issues.
This also fixes almost all of the ipods on ebay that wont sync as well.
Re: Bought a iPod for 10 bucks. [Re: monneysi] #474744 07/29/09 03:29 AM
T
TCPMeta Offline OP
MacModder
MacModder
T
I still got my Nano, comes in handy for listening to music at work.
Last month I saw a first gen iPod at the local pawn shop for a hundred.
