• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Mods and Hacks » Software Hacks & Mods » Configure 6 Channel Stereo Output
Page 2 of 3 < 1 2 3 >
Topic Options
Hop to:
#474527 - 02/05/08 05:44 AM Re: Configure 6 Channel Stereo Output [Re: retoiopikott]
macDeviant Offline
I did a little searching around for myself on this. about the only way i could figure it was to use the FireWave in music mode, and adjust the trim and dimension settings.
I was having some problems with sound and the stability of the firewave software. i changed the FW cable and it works much better now.
good luck... if you do find something else let us know.
Top
#474528 - 02/05/08 07:18 AM Re: Configure 6 Channel Stereo Output [Re: retoiopikott]
JediJoker7169 Offline
Awesome
Thanks for the cable tip.
The speaker control box actually has its own trim settings, so I could use those, but I'd so much prefer a native 6 channel solution.
Cheers! :-)
- JediJoker
Current:
- "ProBook:" 15.4" MacBook Pro Core 2 Duo 2.33 GHz
- Mac Classic II
- Old PowerBook
Moved On:
- "The Book of Power:" 12.1" PowerBook G4 Aluminum 1.33 GHz
- Purple iMac
Top
#474529 - 02/05/08 09:13 AM Re: Configure 6 Channel Stereo Output [Re: retoiopikott]
macDeviant Offline
Originally Posted By: "JediJoker7169"
The configuration I'm trying to achieve is this:
- Left Channel: Left Channel
- Right Channel: Right Channel
- Center Channel: L/R Mix
- Surround Left: Left Channel
- Surround Right: Right Channel
- Subwoofer: Low Frequencies
[/url])?
Well if you want the L/R Mix in the center channel then I believe you will get that out of the "Music" setting in the FireWave setup. It's Pro logic II but it is in stereo. If you have all the speakers sitting in front of you, then you just need to play with the trim and dimension settings to equalize the output volume of each speaker.
This will give you the desired effect with out any other equipment, connections, software, or frustrations. I tried it out my self on my own FireWave, and it sounded pretty good.
My situation was similar to yours. Except I was connecting to different receivers on different sides of the room, with their own speakers. That's why I ditch my iMics and went with the FireWave. Either way the results should be the same. ;D
Top
#474530 - 02/05/08 10:06 PM Re: Configure 6 Channel Stereo Output [Re: retoiopikott]
Awesome
Well, ProLogic II is all fine and good (I use it on Music mode + Panorama all the time), but it doesn't evenly distribute all sounds to the surround speakers. For example, crowd noise would be louder in the surrounds than the lead vocals. It's cool, but not what I'm going for, although it seems I may not really have a choice.
Cheers! :-)
- JediJoker
Current:
- Mac Classic II
- Old PowerBook
Moved On:
- Purple iMac
Top
#474531 - 02/09/08 11:19 PM Re: Configure 6 Channel Stereo Output [Re: retoiopikott]
Awesome
Okay, so you can't setup 6 channel stereo with an external soundcard, but what about using optical out? I just bought a gently used Creative DDTS-100 so I can set up my Xbox and DVD player in my office. It has optical in (among other formats) and analog out, and does allow for simple passthrough, I believe. It encodes/decodes DTS (including Neo:6) and Dolby Digital (including ProLogic II Movie and Music modes), so it can replace the FireWave. Or: it has an analog switchbox, so I can keep the FireWave and use it in combination with the DDTS-100.
Just to get back to the point of this post, I want to know: using Apple's Audio MIDI Setup Utility, is it possible to configure 6 channel stereo using optical output?
Cheers! :-)
- JediJoker
Current:
- Mac Classic II
- Old PowerBook
Moved On:
- Purple iMac
Top
#474532 - 02/14/08 04:16 PM Re: Configure 6 Channel Stereo Output [Re: retoiopikott]
Awesome
I have decided to deep six the FireWave. The DDTS-100 encodes/decodes at higher quality. Unfortunately, I seem to have misplaced my optical cable, so I haven't been able to test what I asked about in my last post. However, the DTS Neo:6 Music mode seems to be pretty close to 6 channel stereo (unlike DD PLII), so I may just forget it.
Cheers! :-)
- JediJoker
Current:
- Mac Classic II
- Old PowerBook
Moved On:
- Purple iMac
Top
#474533 - 02/22/08 08:14 AM Re: Configure 6 Channel Stereo Output [Re: retoiopikott]
macDeviant Offline
Okay I think I found something of consequence. Okay you just want 2 channel stereo out of your 5.1 system. By this you mean you want the left channel to go to the left front and left rear, the right channel to got the the right front and right rear, and the center and sub to be whatever they come out as...
Some how I came across this basic little adapter from logitech
please google
970150-0403
It's cheap and just might do what you want it to.
Top
#474534 - 02/23/08 08:52 AM Re: Configure 6 Channel Stereo Output [Re: retoiopikott]
Awesome
I think that's actually a little more complex than it looks, as it's advertised as creating "intense realism." But, as I said, I'm rockin' on DTS Neo:6, which is the next best thing to 6 channel stereo, and I have no complaints.
Cheers! :-)
- JediJoker
Current:
- Mac Classic II
- Old PowerBook
Moved On:
- Purple iMac
Top
#474535 - 02/26/08 07:34 AM Re: Configure 6 Channel Stereo Output [Re: retoiopikott]
Awesome
OK, this is getting really annoying...
The optical audio connection is mostly amazing. I say mostly because, while it's amazingly clean and crisp, it's not without problems. My guess is that the MBP's soundcard just ain't doin' what it should.
Here's my problem: if there's a constant stream of audio to the decoder/speakers, it sounds great, but if that constant stream is stopped, the next sound to get transmitted gets cut short on the front end. This is especially annoying when it comes to quick sounds such as those I have set for instant messaging (Morse and Tink; the Tink actually gets cut completely). Is this because the optical laser is only switched on if there's sound being produced?
Cheers! :-)
- JediJoker
Current:
- Mac Classic II
- Old PowerBook
Moved On:
- Purple iMac
Top
#474536 - 03/01/08 06:31 AM Re: Configure 6 Channel Stereo Output [Re: retoiopikott]
Awesome
HALP PLS!!1!
KTHX BAI
Cheers! :-)
- JediJoker
Current:
- Mac Classic II
- Old PowerBook
Moved On:
- Purple iMac
Top
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.038 seconds in which 0.026 seconds were spent on a total of 14 queries. Zlib compression enabled.
