yea, I know what you mean about the pinkish color. Its just a diluted and toned down shade of the maroon used in the logo.
As for the login, is anyone else experiencing this issue? I haven't been able to duplicate. Try clearing out all your macmod cookies and see if you are still experiencing the login issues. As for the funny bottom... There really isn't a solid solution for using div layouts, its one of the pitfalls for writing code properly. There are of course some nasty hacks that I will look into applying. That was just at the bottom of the list at the moment, since that only appears on very short pages.
Thanks for pointing out these issues. Please let me know if you notice any others. Thanks!
The 6KB limit on avatar filesize is moronic. I can't even find an avatar that's less than 8KB in size, and all the good ones are bigger. Can it be upped?
Cheers! :-) - JediJoker
For some reason, the forums forgets me each post. Whether I am posting the first time at the site for the day or the 3rd time, I always need to re-log in.
