I think apple makes the requirements higher than is necessary so that it has room for running programs and all that - keep things running smooth. Also, I think they're going to make an intel only OS sometime soon, so maybe 10.6 will be G5 or better, and then 10.7 intel only. Gotta do things incrementally so that its not a sudden thing. Either way, the people who bought the G5 quads won't be happy when it happens.
Loc: Vancouver, BC Canada
Actually you can put 2x2GB in the macbook, macbook pro, mini and lower end imacs but they will only recognize 3.3GB. This is why 3GB kits exist and not 4GB.
Even though you would have a matched pair with 4GB I doubt you would get all the possible matched performance as it wouldn't recognize over 700MB of one of the 2GB sticks.
Well, this thread has taken a turn. I would have to guess that the new OS will use around 100MB running in the background. With so many apps built into the OS, there is of course more ram needed. I suspect that my QS will be marginal running 10.5. I will be sure to run two OSs for some time yet.
My Tiger Kernel is currently munching about 140MB. Thats on a MacBook though. I'll bet the PPC version is way smaller. Intel versions of the OS have been much bigger to date. I wonder if any kind of optimisation in Leopard can help with that. I bet there are certain tasks which would run massively quicker in a G5 quad than in a Mac Pro with the same amounts of RAM.
So the new cpu went south while trying to get to 1ghz. It went straight to OF. After lowering the speed, I only get a black screen. I suppose I will try working on it again when I have more time.
#473929 - 10/21/0711:16 PMRe: cpu upgrade
[Re: Anonymous]
Antonio
NArF!
Loc: San Francisco, CA
You can probably put a 1Gb DIMM in with a 2Gb DIMM and reap the same benefits, so long as all other specs are equal.
Maybe not quicker, or if so, not by much, but certainly less resource-hungry.
#473930 - 10/21/0711:19 PMRe: cpu upgrade
[Re: Anonymous]
Antonio
NArF!
Really? Okay, question time (as I don't know the specifics of your Frankintosh)... Are your logic board and PSU also from a QS, and if so, the same revision?
#473931 - 10/21/0711:31 PMRe: cpu upgrade
[Re: Anonymous]
Antonio
NArF!
Ah, just thought of something: you may need to use a utility to lower the speed of the L2 and/or L3 cache on the new daughtercard, as overclocking of course increases the speed of cache, as well.
You would need to set the speed with the old daughtercard installed, of course, but the new one would inherit the very same settings, which are set as a ratio to CPU speed.
