Loc: Avoiding Direct Sunlight
I have a red 2nd generation Nano and an almost perfect condition black 1st generation nano, and after comparing them for a while, i really like the 1st gen scrollwheel a lot more. Is it possible to transplant a 1st gen wheel into a 2nd gen nano?
Even if the connectors on the click wheels are the same, working on a second gen Nano is not going to be easy. The iPod minis were a pain and these Nanos use the same aluminium tube design only much smaller.
I hear ya.
Hows this. I have to fix this 2nd gen Nano and I have a 1st gen laying around. I'll probably have to part across from the 1st gen to get this thing working. While I am doing this, I'll check to see how do-able / worthwhile it would be.
hmm. ok, that sounds cool. i probably won't even attempt it until i need a new ipod anyway, since i really don't want to be ipod-less due to a mistake or something.
Well...iPod is toast. It appeared from the outside that it was just a bad blow to the display. Turns out the connections are also water damaged. Took a soldering iron and touched up the ones I could (after cleaning w/ isopropyl), but it still will not recognize. It's a shame, but no need to keep the board around. Keeping the battery and case.
To add more detail to my previous post, the really tricky part was getting the damn thing back into its tube. There is no play at all. And that was the mini.
