Hey guys whats the Most Jacked AGP PC video card that i can falsh and put in an AGP G4 because i'm getting one soon for cheaps and i want to max it out like crazy.
AGP as in Sawtooth? If so then probably the Radeon 9800 pro or Geforce 6200, Those are the best for a 2x AGP slot. If your gettin the Digital Audio Or Quicksilver then the Geforce 6800gt or 7800gs (7800 with g70 core). Or if by Jacked you mean the worst than the Rage 128. lol
Mac Pro Powermac G5 Powermac G4 DA Sawtooth G4 AGP Powermac Cube Atari 2600,
Well. this post is a couple years old so by now the video cards are newer and perhaps you have moved onto a newer model card. Which solution did you end up choosing?
