Loc: Vancouver, BC Canada
I recently bought one of the new Core2Duo mini's and even though in many ways its a total screamer I find the HD access speeds bog things down often enough to be a drag on my user experience. Plus the stock 80GB won't be enough looking forward.
My options are either upgrade the internal 2.5" (Hitachi 80GB 5400rpm 8mb) to a Seagate 7200rpm 2.5" 160GB 8MB buffer I can buy a a local shop - OR - buy a http://eshop.macsales.com/shop/ministackv3 FW drive from OWC. I would think that an internal SATA 7200rpm even though a 2.5" would be faster than a FW drive in some ways.
Thoughts?
Edited by (09/30/0708:36 AM)
Well, it's not like the original mini. Your best performance upgrade would be sticking a faster internal drive in your machine. I'd go that route for sure.
Also, try having a boot partition thats journaled and a secondary "Home" partition non-journaled. See if you get the freaky speed boost that I got on my MacBook. You may be happy with what you have and end up getting the ministack.
Also the PowerPC mini's used 4200rpm drives and the intel's use 5400
Internal 7200 SATA will give me the best performance in this situation. Some benchmarks I have seen put some 2.5" 7200rpm SATA around 70MB sec. Firewire maxes out at 50MB sec..
Internal for me
I just swapped out the 60GB 5400 in my MacBook for a 100GB 7200rpm. Finder is as snappy as any Intel Mac I've used under 10.4.10. Yet to see anything match the dual 2.5 G5 tower (single core) under Panther though. It was as quick as OS 9......
