• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Mods and Hacks » Laptop Mods » Case Mods » iBook G4 Mods
Topic Options
Hop to:
#473402 - 09/05/07 06:38 PM iBook G4 Mods [Re: Phillip2456]
flippy10 Offline
Loc: Pelham
Hey Guys, I'm a bit new here. But I just got my hands on my first real powerful Mac. (though I've been using them since Apple II/si)
Anyway, I've got a couple things I wanted to give a try with my iBook G4.
Specs:
1.2Ghz G4 + 1.25GB DDR + 120GB Scorpio HDD + Superdrive
Now, I really am not quite sure what to do with it. I did the various hardware upgrades, but I was looking for a fun Mod project to really get this thing moving.
I was thinking of possibly modding the top cover, painting it black (Although it's not like the G3s where I can paint it on the inside of the case sadly..) cutting a window in it.. Possibly lighting modifications.
If anybody has any projects they know about, or anything at all. I'm more than intrested. Otherwise, I'm just going to wing it.
I also just got my hands on 2 Pismos that are in severe need of some upgrade and modification. 550Mhz G4 Upgrade Here We come! Smiley
[size:85]I own so many computers, it's unhealthy.[/color]
Top
#473403 - 09/05/07 09:34 PM Re: iBook G4 Mods [Re: Phillip2456]
oojacoboo Offline
Painting is always popular with these models.  Be original, think of something wild and have fun with it.  Thats the point of modding.  If someone else comes up with the idea, where is the fun in that?
Mac Pro Quad 2.66 - 4GB RAM
Quad 19" Widescreen LCDs
Accessorized to the Hilt
Top
#473404 - 09/05/07 11:11 PM Re: iBook G4 Mods [Re: Phillip2456]
flippy10 Offline
Loc: Pelham
See, I already have a unique paint design ready. But I think my biggest issue is that I'm weary to paint atop the hardcover. I really don't want to end up having paint chip off/scratch easily.
Heres the plan so far:
I was thinking a Plastic Primer - Black Flat Top Coat - Polyurethane finish.
My Apple will be turned red using a Red Spotlight Gel.
My middle layer (where the lid hook/sleep light is:
Plastic Primer - Flat Grey Top Coat - Polyurethane finish
And the bottom is going to be stock white.
I was also thinking about adding dual white LEDs to light up the keyboard in darker areas.
Does anybody know if the translucent key iBook G3 keyboards are compatible with iBook G4s? Because solid white keys really don't do too well when it comes to lighting. (iBook G3 12' - iBook G4 12')
I'm having trouble coming across some information on painting the iBook G4's plastic white case... I just want to make sure I'm using the right combination of paint/finish. I don't want to have it start to chip. smirk
http://www.applefritter.com/hacks/tronbook
(This makes me sooooo jealous of iBook G3s.)
Edited by (09/05/07 11:24 PM)
Top
#473405 - 09/08/07 06:32 AM Re: iBook G4 Mods [Re: Phillip2456]
flippy10 Offline
Loc: Pelham
Ok, a bit of a change of technique/idea. But same stuff basically.
I painted both the top cover panel and the bottom panel. I used a black metallic paint and engine clear coat (resistant up to 500F smile ) I took both panels, and sanded them with 1200k grit sand paper. I cleaned them afterward throughly with rubbing alcohol and then the fun starts. Since the black metallic I got was made for toolboxes, it's basically already pretty gouge-proof (tested or I wouldn't beleive it.) but the engine clear coat is there to seal the deal. I put the first coat of black on. waited 5 hours, second coat of black. Waited 6 hours. 3rd coat of black. (in between-- wet sanding each time.) and finally I just put the last coat of black on. Tomorrow when I awaken I will finish clear coating (3 coats) thing should look way sexy when it's finished though. I left the inner parts white (inner screen bezel and hand rest/keyboard.) I'm now looking for a fully intact iBook G3 15' keyboard or a 12' one would work too.
I need to find someplace to tap 3-5v from that only is powered when the computer is on. If anybody knows of a good spot.. Please note. Or it's to the multimeter I go!
Top
#473406 - 09/08/07 01:52 PM Re: iBook G4 Mods [Re: Phillip2456]
soundmann18 Offline
you could possible get that from usb, although I don't know much about that.  I would try to add some type of switch so you can turn off the lights, like if you're trying to watch a movie on it or are taking it out and want to conserve battery life
__________________
15" MBP late 2008
Top
#473407 - 09/08/07 07:47 PM Re: iBook G4 Mods [Re: Phillip2456]
flippy10 Offline
Loc: Pelham
Wow, I'm retarded I completely forgot USB uses straight 5v.
It'll have a small toggle that I'm painting white and integrating so that it doesn't protrude out of the case.
Sorry I don't have a mod guide.. I tried to take pictures but my camera is the ultimate crap.
I'm sure this has been done and overdone anyway. smirk
Aside from that though, it's only two white LEDs which won't shave too much off the battery time. But regardless, it's really just for show.
Edited by (09/08/07 07:57 PM)
Top
#473408 - 09/09/07 06:35 AM Re: iBook G4 Mods [Re: Phillip2456]
flippy10 Offline
Loc: Pelham
iBook just died. High five for me being a complete ass.
Won't respond to power button, tried removing the battery for 5 minutes and trying again. No dice.
Top
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
View homepage
Add to your Watched Users
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.041 seconds in which 0.026 seconds were spent on a total of 13 queries. Zlib compression enabled.
